Mazda Lowering Static \  Fuel Pump Proublems...
views 728
replies 6
erock   +1y
I installed a new fuel pump and it started to flood my weber carb so i bought a brand new weber 32/36 and i started it up it ran for about 10 seconds then the weber flooded and started shooting out fuel then the engine would die. any ideas??? i tried to adust the mixture screw and the idle screw to keep the engine running but it would just run for about 10 seconds , shoot out alot of fuel then die again.={
guam671   +1y
If u have an electric fuel pump , the psi on it might be too strong for your carb.
kovz   +1y
Is it a low pressure electric pump? Fuel injected pumps run at a higher pressure.
Do you have a regulator between the pump and the carb?
sahankaface   +1y
Is it a auto tranny or 5 speed and is it electric pump or manual fuel pump.5 speed tranny is a diff fuel pump it is a manual fuel pump and auto trannys are electric pump
erock   +1y
i have an automatic and no i dont have a pressure regulator. but im pretty sure i got an electric pump. where could i place the presure regulator? could i just add it anywhere on the fuel lines?
kovz   +1y
I mounted mine to the firewall. It is inline after the fuel filter, before the carb.
erock   +1y
right on thanks everyone ima give it a try and let you guys you know how it goes
