Mazda Lowering Static \  wire harnes after weber swap??
views 863
replies 6
chrismp91   +1y
the leftover wire harnes after instaling the weber ware it hooks to the egr valve below the carb and a green conector sencor thing on side of the manafold can i remove all that also?
sincitylocal   +1y
Yes, all sensor wiring and egr stuff can be eliminated.
Just don't get rid of the temp sensor wiring.
Cusser   +1y
I'd keep the little vacuum/electric controls you take off the passenger side firewall, even the old carb/air cleaner/tubes, etc. Over the last 6 years I've sold most of what I pulled when I installed my Weber in 2005.
Sooner or later, someone always wants something. Like someone needed the idle-up stuff for his added aftermarket AC, someone else wanted the rubber hose from air cleaner to the front, someone bought the air cleaner assembly with its new filter, etc.
chrismp91   +1y
everything has ben removed but that green sencor conector on the manafold and the egr thing by the nipple on the gold housing wats that oxygen sencor for?
Cusser   +1y
Leave the oxygen sensor in place; for you: it seals the exhaust system !!! The wire will do nothing for you.
chrismp91   +1y
ok i left it in the exhaust and cut the wire but what about the little green hook up that screws into the manafold? i un hooked it and its not a timp sencor but i un scrued it and anti freeze came out so what is it is it importnant?
Cusser   +1y
That's a coolant temperature sender, but not the one to the gauge (that one is under the thermostat housing); like the O2 sensor, you only need that as a plug now.
