welded gears?
marshalltoneyiii@gmail.com's avatar
welded gears?
5bigb5's avatar
5bigb5
I want to weld the gears in my 2wd b2200 I don't know much about these rears I was wondering if the axles will hold up.the main abuse would be 'drifting' haha
dvsdev's avatar
dvsdev
They make a LSD that is a factory option, why not just upgrade?
A locked diff is pretty rubbish to drive with and even for drifting a LSD is a far superior option, if you're serious about drifting your B series do it properly, ditch the frame, make a tube frame, get rid of the torsion and leaves and run coil overs, you'll get better results if you change the rear axle to a IRS setup, which will give more control over suspension geometries, might as well ditch the 2.2 motor and run something with nads like a NA rotary, sr20det, Nissan v6, or 2jz.
Or if you just want to flick a few donuts and have some fun, get a spare rear axle setup from a donor, weld that, destroy it, and replace your factory assembly later on.
5bigb5's avatar
5bigb5
Yeah I'm just lookin to do some donuts the trucks bagged so itl probly never be much of a drift truck haha.I'm fine with driving a locked rear cuz its just a toy I just don't wanna be spittin axles out all over the place
sincitylocal's avatar
sincitylocal
It won't break the axles, but the gears will eventually break!
Normal driving will scrub the tires, so don't expect them to last long either.
5bigb5's avatar
5bigb5
I know but I have a spare rear I was just gonna have a welded one and a normal one and change the 3rd member whenver I wanna do dumb shit
