General Discussion \  89 B2200 Turn Signals do not work, flashers do work... thoughts??
General Discussion
views 4136
replies 2
following 2
ndross475   +1y
Checked Haynes and the 89 allegedly uses a dual relay for both flasher and turn signal, I guess one side could be bad, for $20 I am thinking of ordering one to give it a shot. Anyone else have this problem and find a solution? I have tried to search the site and can't find a thread, some show in google but the links are still busted.
robzilla   +1y
The flasher relay could be bad. Mine is located in the driver side kick panel area. Also another issue could be dirty contacts on the switch. I had to clean mine. There is a good write up by Axel breaker earl for reference that's what I used when I took mine apart.
http://www.mazdabscene.com/wiki/70
ndross475   +1y
Solved: My 89 B2200 has one relay that controls both hazard and turn signal, while my hazard lights worked and my turn signals did not, I thought the relay could be good. It was not. I replaced it and they both work now.
