Ranger Engine \  Need Tranny Help!
Need Tranny Help!
Ranger Engine Ranger Tech
views 927
replies 3
baha   +1y
Ok this weekend I replaced my pilot bearing, release bearing, clutch and pressure plate in my tranny and now its all back together and I can't move through the gears lately, I'm guessing the clutch is enganged since it is brand new and stuck in gear since I put it in reverse when I put the transmission back in. Any Ideas on what caused this and how to fix it? Also I don't have the hydraulic clutch line hooked up and Im hopeing praying thats all I have to do please help lol
infernoford   +1y
without the clutch line you wouldn't be able to disengage the clutch at all
scrp1day   +1y
from the litte tranny work ive had todo on my budies car i waould say the hydro line is your problem. we had the same problem as far as stuck in gear just ripped it back apart checked everything put it back together and voila just worked sometimes it just helps to go back over it.
wanna b lower   +1y
i took a trans class last semester and from what i know whithout the line hooked up you wouldnt be able to move through gears very good at all so id say hook it up and see what happens
