stock flooring?
stock flooring?
F
fatman
could i use 21/2x21/2 and still manage to lay rocker or would i still have to do a traditional bd also any help is appreciated thanks (ive gotta figure out what im doin here)
E
exploitedcustoms.com
Yes that would work. I used 3x3x1/4 on mine and I lay the rocker.
bodydropped85's avatar
bodydropped85
i prefer 2x3
chunky_thunder's avatar
chunky_thunder
i agree with James 2x3x1/4 is plenty that is what i used
scrp1day's avatar
scrp1day
not to thread rob but what do all these numbers mean? just tryin to get educated!
E
The dimensions on the tubing that is used when you build a new frame.
2"x3"x1/4 thickness
scrp1day's avatar
scrp1day
ooooo. i see. so when doing a sfbd you have to do a whole new frame then? sounds nuts!
scrp1day's avatar
scrp1day
i never knew that much work went into it
Post was last edited on Jan 09, 2006 01:09. Edited 1 time.
E
Yup you build a new frame from firewall back. Or you can modify your stock frame to some extent and get the same results basically but it comes out a lot cleaner if you just build your own frame.
If you go to my website and go under projects and click on the ranger picture you can go through and look at some of the frame pictures to see what's done and that.
scrp1day's avatar
scrp1day
thanks ive been on theire and other sites all day just browsin. ill check it out thanks. btw my wife ordered an emergency release from you do you know how long until that makes it my way?
Related Discussions in Ranger Suspension
