LED problems
LED problems
shavenotbagged
Alright i have a 95 and uhh ya ive never done wiring b4 so i bought the FBI leds and put them in they were 3workin fine even though i didnt have the wirign diagram and it was starting to like some of the bulbs started burning out i was just wondering is there anythign i can do about it besides replacing the hole light and if anyone has or knows someone that has the FBI wiring diagram for their LED TAC units hit me up ineed it bad casue if not ima hafta buy all new shit thanx
tiger's avatar
tiger
I think I deciphered that...
You probably got your hot and ground backwards. LEDs have to wiried up in a certian way, they aren't like filamanet bulbs where it doesn't matter which lead you use as hot or ground.
Since you've never done wiring before, it'd be easier to just replace the whole thing, because the only way to 'fix' the aseembly is to tear it apart, unsolder the burnt LEDs and solder in new ones.
I
itsarealedgeiswear
Not to be mean but could you edit your question a little better so that it isnt a complete run on sentence I cant tell what the hell your asking.
What does the FBI taillights look like all red red/white red/yellow/white.
Do your turn signals not seam to work on the rear when you brake? A friend of mine had the all red LED strips on his truck and I told him to get Import trailer tailight harnesss adapter and it fixed that.
If he had them wired up backwards they wouldn't work at all LED's are polarity sensative the only kind that actually work backwards are zener diodes and they dont light up.
Some more info on how you hooked it up and what you exactly have would help.
shavenotbagged
all i did was i bought brand new stuff becasue i didnt want to mess with it all and try to figure it out this time i am goin to make a bunch of copys of the wiring diagram so i dont loose the one iget
Related Discussions in Ranger Exterior
