my 89 mitsu mighty won't pass smog i think it takes about 5 minutes to warm up . New plugs, wires runs great when its warm doesn't want to idle and runs rough when cold when it warms it makes a baffle soune what are some of the things i can check myself that has to due with smogging?
It would help by telling us what exactly it is failing on the smog test, nox, co2, etc... what it is and what the passing numbers should be.
How is the distributor cap(any cracks,moisture inside) and rotor, big possibility the carb is going out as these electronic carbs have a tendency to fail.
results
co2% 02
% hc (ppm) co(%) results
test rpm meas meas max ave meas max ave meas
idle 1044 1390 1.50 120 30 26 1.00 0.10 0.00 pass
500 rpm 2442 1380 0.00 180 20 119 1.00 0.10 1.70 fail
all visual inspection of pcv dist sensors vacuum line etc all passed
The numbers are all jumbled together ,if it was in easier to read format it would help. Also if you know which part you failed nox,co2, etc just do a google search for what would make that gas high and what you need to do/replace to get it into specs. Also post your test info in a thread on mightyram50.net as there are plenty more active members on that site.
