Rear end
Rear end
brendo
im looking to put a new rear end in my 86 d50 or just rebuild my existing one. is anyone running with a posi or lsd? i dont know what i should go with. im not makingalot of power but i would like that extra traction. what are the stock gears in these trucks?
thanks guys!
E
evlb2k
i was running a single spinner in my 4g63t 83l200 and had bugger all traction, i changed to a lsd andgot heaps more traction but it steps out in the bum alot more where the single spinner would just spin up and keep going streight, i was running a 4.6:1 lsd but it was to tall and could only get 100mph on the 1/4mile, i have since changed to a 3.9:1 lsd, i havnt tryed it down the strip but is better up top, i think a 4.3:1 would be best.
Your gearing could be anything youl have to count it, theres abit of an art to setting up a diff head properly so unless yourv got the right tools i wouldnt recomend it, hope this helps
brendo
this helps alot. thanks man. okay now my next question is what kind of lsd should i get? should i pull my old gears out and re-gear it with an lsd in it or buy an axel already set up for it? if i should redo mine is the an lsd that is better then others for the price or is it just get what you can?
E
evlb2k
the factory lsd can handel quite alot of beating, prob be ezer to find a lsd diff but you can change the crown wheel and pinion to get the gearing you want, i put the crown wheel and pinion from a single spinner onto a lsd unit, i went to the local mitsubish dealer to get the info to rebuild mine, if you cant find anything i might be able to scan what i have and send it to you
brendo
thanks but that still kinda leaves my question open. okay so to clarify things. i have a stock diff(single spinner) i wanna throw a lsd in it. what should i get? rebuild stock diff with a lsd? or buy a random lsd diff?
thanks for all your help guys
E
evlb2k
the ezyst way to go is buying a diff thats already lsd but if it isnt the ratio that you want you can change it
brendo
okay, thank you. what would you recomend for a diff?
rickdees
If you can find a first gen Montero or Raider, some will have the LSD in them and will fit in our trucks.
Look for an orange sticker on the drivers door post,
or a yellow sticker (same place, it will say use limited slip lube)
There also could be a yellow sticker on the back of the pumpkin saying the same.
The year goes up to 88
(NOTE: the V6 limited slips will not work on the first gen trucks )
ONLY FOR THE 4 BANGER
If I remember correctly, You'll need 12mm, 14mm wrench, and a hammer (Take more tools of course). I pulled one in 45 minutes, that is walking in @ u-pull it and back out the door. (the last one I bought cost $59.00, In Oregon of course)
If your gears are in good shape? You can use them. The montero and raider have 4:63 and higher
The 2wd trucks either have 3:54 (manual trans) or 3:90 auto
The 4 wd truck (manual trans) 3:90, Yeah, there IS a automatic 4wd truck....RARE!!
YES these read ends are TOUGH, I narrowed a 95 Ford explorer 8.8" rear end for my truck. Ford rates these axles at 3500 lbs. The Mighty Max/Ram 50 axles are 1/16" smaller than the Fords.
The Mighty max/ram 50 is 7-1/4"(ring gear) It looks small, But it is very BEEFY!!
I hope this help you out some, now try to find and Montero or Raider
Out here in the great northwest there are MANY, east is a different story...
This is a 88 Dodge Raider chunk
Post was last edited on Nov 21, 2009 02:59. Edited 3 times.
rickdees
Oh, they will ALSO fit 2nd gen trucks.
same rule, both must have 4 cylinder engines
V6 is for V6
jdobos
ok Ive read everything here...and I dont pretend to understand rear end gearing.. I also want a posi unit. I need gears that will work for highway and intown use. I have a 87 50 with a 2.6 and manual trans. What do I need to look for? And/Or does any one have one for sale?
