horsepower for 2.4
horsepower for 2.4
dale
Does anybody got any cheap quick ways to make my 91mm go faster i tryed to put a cold air intake on it the ox senser wont let me let me know..... thanks
sleeps
The o2 sensor wont let you? How does that work?
Ill try and help. Cold air intake wont give you any real usable HP. It looks cool, but thats it. If you want to make that engine go faster your going to need to rob a bank. Performance parts for this motor dont exists. You have to make them or steal them from other Mitsubishi models and make them work. Id suggest leave it be, and save your money for a vehicle that has the market and base for performance. Good luck.
dale
N
nate10
If u take ur fan off an put an electric 1 in u can reduce a lot of drag off the motor. Anythig u can do to reduce drag off the motor will give u power. U can adjust ur cam timing a little bit. Change the muffler to a bigger size. I have a 2.25 inch system on mine an it woke it up a little. Tryig running sybthetic oils in ur motor trans an rear end.
dale
OK COOL THANKS MAN
