bogging down
bogging down
c03camson
Recently got my 88mightymax running again. Changed the plugs and air filter, fuel pump looks good. my problem is the more gas i give it, the more it will bog down. then if i let off the gas a little and get back on it, it will be normal again.
I am thinking that maybe the fuel pump might be getting clogged or needs a new fuel filter. Also maybe it might need new wires or distributor. The carb looks good, cleaned it with carb cleaner, didn't soak it or anything.
Another thing too, once it gets warmed up and quits revving so high, it will barely idle and want to stall out if i don't give it gas. Any ideas?? Thanks
droppedmitsu's avatar
droppedmitsu
I would definitely change the fuel filter, located on the drivers side on the side of the fuel tank under the bed. There is a screw to adjust the idle, can't remember exactly which one it is so if you had a manual you might try adjusting that. Also running some seafoam(engine/fuel treatment) through re gas might clear out any gunk in the fuel system
