General Discussion \  1 piece back glass conversion
General Discussion
views 955
replies 3
following 2
istunt   +1y
As title states im plannin on doin this tomorrow, i found a 1 piece glass at a junk yard but its still in the vehicle. Any idea on how to take it out with out damaging the gasket around it so i can reuse it? Thanks
nate10   +1y
On the bottom of the back window on the left an right sides there are a little dimples. One on each side about 3 inchs from where the window starts. If u can get a screw driver in there to pry the seal out easy it should pop out after u work the seal about half way around. Use a bottle of what or something with u to wet the seal so when ur prying on it u dont tear the seal.
istunt   +1y
Thanks alot for the tip, ill be attempting to try this this weekend.
nate10   +1y
If u have a sliding back window make sure u get the seal off the solid window cuz i think there differnt. An if theres anouther 1 at the junk yard practce on it 1st then do the 1 u want.
