HIDS info?
E
HIDS info?
pattymelt
I recently installed a hid kit on my 92 mm the kit came with projector headlamps and the beam is going all over the place with the edges looking like spider webs. Any advice how to change or similar problems???
droppedmitsu's avatar
droppedmitsu
That is what is going to happen. You put HIDs in a regular halogen light housing, they are not meant for hid only regular halogen bulbs. If you want to do it right you need to buy a projector retrofit and pull apart your headligts and install a projector in them. That is he only way to PROPERLY install hids and it cost $200+ and it is a little bit of work.
pattymelt
I did that. The kit I installed had a projector lens I installed that with the hid bulbs. And the beam isn't solid on the corners
droppedmitsu
That is not a real projector housing, guessing u got a universal "projector" 7x6 headlight housings? You need a real projector lense like what comes in a high end luxury car headlight.
Here's a link to show you what you need if you want real hids.
Here's link to ://
Here's link to how it would look and how you do a hid retrofit:
" target="_blank
N
n3rd702
Does this kit fit into the stock MM headlight housing?
droppedmitsu
No, first you have to get some universal 7x6 housings which have a h4 size(or similar) bulb that can be replaced. Then you have to open up the headlights to install a projector. This is the only true way to get real PROPER hids. Read the second link it shows how to perform a hid retrofit. It is for a tacoma but applies to any vehicle which did not come with hids.
