fan shroud ?
kennyfranklinjr@gmail.com's avatar
fan shroud ?
baggedbmy93mazda's avatar
baggedbmy93mazda
will a 2-piece metal fan shroud from a 95 mighty max with a 2.4 fit an 89 d50 with a 2.0.....
trying to help a friend out. any info would be greatfully appreciated
thanks in advance kenny
I
istunt
I think they should since they may have the same size radiator. If you can tell me the size of the 2.0 radiator then i can tell you for sure or not if it will fit.
baggedbmy93mazda
yeah i have to call the guy and ask him to go measure it, i have the 95 max shroud. I can go measure all my stuff and call him and post in a lil bit the info i obtained
thanks man
I
istunt
No problem. If your radiator is around 15 or 16inches and his is the same then they should work. Good luck man.
