Spindles??
Spindles??
aorolfo avatar
aorolfo
I put them on but when i try to tighten the bolt to the ball joint on the lower control arm and outer tie rod the bolt keeps spinning and wont tighten,, how do i tighten the bolt without the tie rod n ball joint spinning?!
droppedmitsu avatar
droppedmitsu
you're saying you cant tighten the nuts for the balljoint and tie-rod? if so try to push them farther up into the tapered hole, or if that doesnt work you may need to get some new ball joints and tie rods
aorolfo avatar
aorolfo
yeah i cant tighten both,, they just keep spinning
