General Discussion \  Steering gear box
Steering gear box
General Discussion
views 2236
replies 5
timmy   +1y
Im woundering if there is any diff. on how and looks of the standard steering gear box and right hand drive steering box. The reason for asking is im doing a right hand swap on my 94 mighty max and wounder if there was a place to buy the steering box? Also does anyone have pics of the right hand drive steering set up?
droppedmitsu   +1y
No need they are the same I believe, if they are not, it will still work all you have to do is bolt it to the right side of the pass frame rail. Plenty of people have done it no problem with lhd stuff just flipping it around.
timmy   +1y
ok thats what I was thinking just wanted to make sure. thanks
92gtseater   +1y
What are you guys doing about the dashboard
laidmazda666   +1y
take your old one and swap sides and move it to the inside of the frame instead of the out side of the frame like the lhd would mount 2 bolt holes will line up the top bolt you will have to make a mounting tab for it but other then that its fairly easy
