Fuel Injection to carb
harmon928
ok so i have a 94 mighty max that is used for a dirt track race car its fuel injected and i want to convert it to carb what do i need to get??
rxinhed
Look up the Weber carb site. Mitsu didn't make carby 2.4s that I'm aware of, perhaps an 80's 2L setup could be transferred?
droppedmitsu's avatar
droppedmitsu
A g63b (carbed 2l in 87-89 trucks) intake manifold should bolt up and then just get a weber carb.
harmon928
what do i need as far in change of wiring?
droppedmitsu
Nothing i dont think, you can grt rid of the o2 sensor if you go back to carb and get a weber, your coil and distributor should still work exactly the same also. You will have to put in the mechanical pump that came on the carbed motors or get a fuel pressure regulator to drop the pressure way down(3-4psi)
harmon928
ok cool thanks for the help
