General Discussion \  PREDETONATION ON 2.6L AND NEED A WEBER CARB
General Discussion
views 1771
replies 0
following 1
robertson5347   +1y
Have a '88 dodge ram sport 4x4 2.6L Having a problem with predetonation. In the past will not run above 50 without valves clanging like crazy and losing power. Now it starts and takes gas fine (revs up normal), but has no power when put in gear and engine will not rev up even when given full throttle. Is this a carb. problem? or timing or other issues? Replaced head with a head from a 1982 2.6L d-50 engine. The only difference is the '82 head has more metal around the valves than the '88 head and the intake bolts are reversed on the lower part of intake which I managed to use washers and nuts to hold it. Top matches fine. Rebuild the engine about 5 yrs ago (about 15K miles). Now I have a blown head gasket between the 2 inter cyclinders. Would the predetonation be the cause of this? Also, looking for a Weber carb. kit wk614.
