4G64 2.4 to 6G72 3.0 swap?
robogorbachov
Does anyone know if the 3.0 6G72 motor bolts up to a 95 transmission? I don't have the specs, but I can't seem to find them either. my piston rod went through my block and I'm looking for an easy engine swap, with possibly a bit more power. If anyone has any information on any of these engines/transmissions, I'll gladly take it!
Thanks.
MV
mitsubishi van dude
do you have a wide or narrow block ??? stick or auto ??? where are you on the planet ????
robogorbachov
Sorry man. My head is a bit jumbled since my engine blew two days ago. Its a 5 speed narrow block. original engine and transmission out of my 1995 2.4 4G64 macro cab mitsu. I live in new Hampshire.
MV
mitsubishi van dude
you can use a front wheel drive 2.4 expo/summit/colt/eagle or a 2.o rear wheel drive d50/ ram 50 some hyundais
droppedmitsu's avatar
droppedmitsu
Are you sure its a narrowblock? Truck 2.4's should be wide block, measure across the lower two bellhousing bolts. 12.25" narrow, ~13.5" wide
It should bolt up to the 3.0 engine since the trucks did come with a 3.0 v6 6g72.
