Max Engine \  Needing help with my timing
Max Engine Max Tech
views 990
replies 7
following 2
qballd50   +1y
I have had problems with my truck for a while now and can't get it running right,
on the dist.- Is This Right With the 1 2 3 4. on the Dist.
I think I have my timing off really bad and when i adjust the Dist. the engine dies one way and the other it runs really bad
cyrus   +1y
Looks like your one off. If you have an 88 it looks like you need to go with diagram two buddy.
Post was last edited on Aug 17, 2009 04:08. This post has been edited 1 times.
qballd50   +1y
Thanks Buddy!!
Tryin to get it together Before the show in Millington!!
cyrus   +1y
What are the dates for the show?
qballd50   +1y
Sept. 5th is when the show is!
qballd50   +1y
Got the Timing right Now but I'm having Fuel Problems Now so bare with me!
I can start it up , runs fine, idles fine, Give it gas and it dies on me!
So i' going to swap carbs with the other truck i have and see what she does then.
I'll let you guys know Mon!
qballd50   +1y
Well That Didn't Work Either!!
Swapping the carbs didn't help!
Any Suggestions!!!
qballd50   +1y
After all of that, all it was, was the Coil Being Bad!! That's Crazy!
Thank You Cyrus For Your Help!!
