Max Engine \  Is the 2.0L cyl. head the same as the 2.6L head?
Max Engine Max Tech
views 1238
replies 4
ronski   +1y
I have a 1980 D50 with a 2.0l with a bad head, there is a long block 2.6l available to me and i was wondering if everything would swap over from one engine to the larger one. Like Exahust manifold, intake, front engine accesories, ect. Anyone know this for sure?
Thanks,
Ronski
droppedmitsu   +1y
No, they are not the same. The 2.6 uses a timing chain, while the 2.0 uses a timing belt. Most likely the exaust ports are different.
ronski   +1y
Are you sure? I have my 2.0l torn down rite now and it has a 2-row timing chain plus anothe single row chain for the ballance shafts. It is a G52B. I looked at a pic of both intake manifold gasket on Autozone's web site and they look the same, but I want to know for sure.
qballd50   +1y
Well Then your Truck Is a 2.6L Engine, Not a 2.0L
droppedmitsu   +1y
Oh yes forgot you have the older 2.0, which is in fact a timing chain engine, and is called a 4g52 as you stated. I was thinking of the g63b 2.0 which came in the later 80's trucks. Not sure on the compatability of the 4g52 and 4g54
