Max Engine \  Coolant Leak
Coolant Leak
Max Engine Max Tech
views 1044
replies 3
mnim15   +1y
I recently got a new coolant leak. It seems to leak pretty steadily, even when the system is not under pressure.
It appears to be leaking from the front and/or right side of the block. Any ideas where it could be leaking from? The engine has ~170,000mi, any common failures at this point?
Any suggestions would be appreciated.
ryan4dc   +1y
The passenger side? The carb and all of the coolant hoses are there. Maybe more then a pinhole leak on a hose. Right after the fittings on the hoses usually get brittle and spring a leak.
mnim15   +1y
yeah, passenger side. Sorry, forgot to mention 1991 6G72. Fuel injected V6.
maxxinn   +1y
Water pump maybe or radiotor just suggestions.
