Need help!! Truck running like dookie!!
sallen
What up fellas... Here's my problem. My h20 pump went out on me and I changed it. Well if any of you guys know that when you with that you have to mess the timing. Anyway well I got it all put back together and sure enough I did something and my timing was off bad... Well I got everything back right but I just need that fine tune with a time light. So I have to drain my pocket book once again and get a timing gun today. I got it running great by ear but still not 100%. Anyway my ? Is what are the timing specs. As in what degree do you run these 2.4 at?? Anyhelp would be appreciated. Thank guys.
gringo3825
your range should be between 3-5* BTDC
sleeps
Did you take your timing belt off? I have a 94, 2.4, and I replaced my water pump and did not have to remove my belt. If you did, thats where you timing is likely off.
N
n3rd702
I thought the 2.4 engines were non-interference?
