Max Engine \  silent shaft gone???
Max Engine Max Tech
views 1458
replies 6
beze214   +1y
so the Mcguyver who owned the truck before me (90mm 2.4) for some unexplainable removed the silent shaft from the engine. (-_-) wtf would posess him t odo so? is there some free horsepower (doubtful) thats is restrained with it on? now i know why the thing rocks like a stroked chevy 464. i had to adjust the idle a smidge higher to compensate. i noticed it while diag. frog ass tight coolant hoses and saw a gaping hole in the timing area. no belt, shaft, tensioner. not to mention the tight hoses seems to be a bad head gasket on the exhaust side. te radiator has a gasseyexhaustey odor...no foam or mud butt on the oil or radiator cap...water just vanishes...tight ass hoses...put put starts. so i just assume the whole motor is fucked (like likfe) so not i guess ill get a g63 and try to find an intake that wont aim at the fire wall and brake booster. fml!
sleeps   +1y
Well sir, they remove those because they "think" it will break and cause damage if caught in the timing belt. Very low likelyhood.
slow50   +1y
ya alot of people remove them. alot of people say they do break sometimes they can even seize up and break the belt. ive never experianced it though.
beze214   +1y
mitsu's pop belts regardless. no point in eliminating it unless your making it faster.
sleeps   +1y
Anything that doesnt have proper tension "pops" belts, has nothing to do with it being a mitsu. It gives you more vibration and DOES NOT give you any horsepower by taking it off.
alignking   +1y
guys i had one that the bearing let go in the block ;; turned and scored the block surface so bad; i had to do away with the balance shaft ;; what i did was leave the upper shaft in the block to dead end oil gallery ; and remove oil pump assembly and cut and plug off oil supply in middle of shaft about one inch from pump works just fine ;; still take and beat six cyls with my 2.4
alignking   +1y
ooohh yea guys forgeot to mention about chain ;;; just take out right amount of links ,too only run from crank to pump , and leave bottom chain guide there; i did this in my place no special tools ;; about two years ago now , drives every day ,in different temps ;;; also did it too my [ 88] ram 50 4x4 2.6 winter truck being from maritimes canada so it worked on both trucks and still going no problem.
