Max Engine \  intake manifold swapping
Max Engine Max Tech
views 1132
replies 5
following 2
beze214   +1y
can you use any g6x intake manifold you want? im in process of making my mm into a mmx. im not a fancy schmansy welder nor do i have the access to custom work like relocating intake manifolds throttle body to opposite side. is there any longitudnial facing manifold that fits g6x/4g63?
beze214   +1y
or AT LEAST one that doesnt bump into the brake booster
beze214   +1y
ok i found the evo 7,8,9 one aims toward the timing cover. will it bolt to a older g63? srry im new to dsm and was a volkswagen guy. still love em just wanna asian and i like dsm
sleeps   +1y
I really dont think they "bolt" on, but I have never seen one compared to the either at the same time. Are you actually getting a 4g63 from a DSM and doing the swap or what? And what is a "mmx"?
beze214   +1y
mm=mghty max. im sourcing a jdm g63 from this guy online. i want an intake faceing longitudinaly forward. im not trying to have crazy weld work done in an intake. if i can i'd like it to be as clean as possible so the swap looks stock
sleeps   +1y
I get the "mm", you said from a "mm" to a "mmx"? I just didnt understand what that ment. The only 63's that face forward are the 2.6's from the starions... If the evo manifold bolted up I think alot of people would be using them. And I have never seen it used. Check this site out...
Its the best and most info out there.
