Max Engine \  valve knocking
valve knocking
Max Engine Max Tech
views 1092
replies 3
clyde_80   +1y
I have a 90 Max and I re did my head. And after putting it back on I have a knocking noise, but running like a dime. tons of power timing is set, head was decked and cleaned and new guides and seals were put in!! I need help
john   +1y
Hi Clyde_80,
Could it be a lash adjuster making noise?
If not, try removing all drive belts and see if the noise is still present.
Next, use a stethoscope to determine where the noise is coming from.
John
robb   +1y
This may not relate to your knocking issue, but I have had problems with my #3 cylinder chewing up rod bearings, but since you said you haven't lost any power from the knocking, this probably wouldn't be your issue. I put it out there just in case.
(1985 D-50, 2.6l)
clyde_80   +1y
replaced lifters and i'm good to go. thanks for the info!!!
