What size Weber should I get?
gringo3825
Picked up an 88 D50 with the 2.6L. Was wondering what size carb will work the best. it will be a DD for work. So would like good MPG, but, would like to get the extra ponies a bigger carb could get me. So looking for a good middle man carb.
qballd50's avatar
qballd50
(This Is a quote from another guy!)
The 38 is better on the low end hands down, and also on the mid to high end. Keep in mind the 32/36 was built for replacement of the stock mikuni. The 38 was never designed just to bolt right on a stock engine and perform to your wildest dreams. It was designed to accomodate an engine build to include:
1. Port and polished head
2. Hotter CAM
3. Flat Top Pistons on a .30/.40 bore
4. Headers + performance exhaust
etc etc etc.....This is where that 38 at 426 CFM will rock at low/mid and high end. Your torque at low end with the above mentioned motor work will be 100% better than stock. The 32/36 has better fuel economy. The 38 does not have good economy as it was designed for power. The 38 does not get the same MPG's as a stock mikuni. On my 2.6 I am looking at 12-15 MPG. The stock mikuni got me 22.
gringo3825
I see no mention of the 34 or 36 do you guys just not use them at all?
qballd50's avatar
qballd50
I'm Not Sure Which one Would Be the Best!
I don't even have one on mine but i really want one!
one of these days I'll have one!
What i posted earlier was a quote from i guy i know!
qballd50's avatar
qballd50
Try This>
gringo3825
Did some reading, I think I am going to get the 34/34. It still has the progressive linkage as the 32/36 but weber claims the 34/34 to have a better drive-ability, while the 32/36 is better economy and was made as a direct replacement for the stock carb. Thanks for the info. I will also throw on a header and an electric fan some E3 spark plugs and should get a little more power and fuel economy with freeing of some restrictions on the motor.
qballd50's avatar
qballd50
Cool Man, I have a header on mine but later i'll get a weber!
When You get let us know how it does!
gringo3825
will be ordering it this week so will have an update hopefully next week.
gringo3825
Where is a good place to pick up aftermarket engine parts for these things?
