Max Engine \  Gauge cluster swap not sure which section
Max Engine Max Tech
views 2809
replies 7
slymax   +1y
I recently found a dash cluster with a tach in it I plugged it Up and everything seems to work but the tach, has anybody ran into this problem before? If so how did you fix it? Please. Help me out
mightyman   +1y
I'm gonna step out on a limb here, not knowing much about these trucks..... If your truck did not come factory with a tach in order to use a cluster with a tach your current cluster harness connector may need to be re-pinned. Try to look for wiring schematics for both the non-tach and tach-equipped trucks and it shouldn't be too hard. Hope this helps.
slow50   +1y
ive read there is a plug that has to be connected its in the engine bay i think by the coil. but when i hooked up a tach in my truck i just ran a wire off the coil to the tach.
davethedude   +1y
I have installed a tach cluster in 4 different PU's and they have all worked with nothing extra done to them, just plugged them in. I would suspect that your tach does not work.
slymax   +1y
Well I pulled it out of am automatic d50 I drive a 5 speed mm everything in the back was the same except one little plug that wasn't on the new one I'm gonna swap it over off the old one
davethedude   +1y
One of my swaps was from a 5 speed to an auto, so I assume they are the same
slow50   +1y
i wouldnt jump to that conclusion. there are a ton of people that put these clusters in and have to do something to get it to work. try mightyram50.com theres a write up on there on how to do it.
slymax   +1y
cool thanks man il check it out when I get home much appreciated
