Max Engine \  Timing belt probs maybe
Max Engine Max Tech
views 1033
replies 6
following 2
m0ta   +1y
Hey guys i just got my timing belt done, the truck runs great but after it was done there is a vibration in the engine and a winding sound. any ideas of what it could be?
moto86   +1y
check your crankshaft pulley bolt, if its not to spec it will walk off and tension itself causing a whining sound.
moto86   +1y
basically the harmonic balancer
m0ta   +1y
Hard to fix? and how hard is it?
moto86   +1y
not hard at all , 14mm socket on your crankshaft, 12mm deep socket on the 4 bolds that hold it to you crank timing gear, check those bolts, its the pulley on the bottom
moto86   +1y
sry its a 19 mm sicket on the cranks
m0ta   +1y
Ok man thanks for ur time n help!
