4g64 turbo help?
4g64 turbo help?
mightytravis769
I have been wantin to turbo my 2.4. Plannin on getting a 2.4 16v galant
head for it and working off of that. Besides the head, cam, rockers, and valve cover what would i need off the galant?
droppedmitsu's avatar
droppedmitsu
Look around on projectzerog.com as I believe there is a list of what is needed for a dohc head swap on a 4g64. Ask ifu can't find it and also ask on hotrodcoffeeshop.com forums
mightytravis769
The head i plan on using is a 16v sohc not a dohc
sleeps
You will need at the very least the head and all attached parts, sensors and wiring, ECU... the galant SOHC 16V's are mostly coil pack. So without sensor swaps the stock ECU wont be able to run it.
drifting50
read my post everything you need to know about turbocharging 4g64
