fordman
Team D50
My D50 1986 2.0L auto timing belt has slipped 10 to 12 teeth on the camshaft from TDC on crank - oil pump was 1 tooth off - I have no reasonable explanation or evidence to explain how this happened.
Truck has 130k, put a new water pump and timing belt on 6k ago. Last week, started it up, drove 200', then it just died and would never fire again.
Removed the timing belt, the crank keyway has not broken, timing belt tension was excellent, no evidence of any parts getting caught under the timing belt which could allow it to slip. Next I'll remove the camshaft gear to check if the pin has broken.
Having no explanation for this problem would severely reduce my confidence in the reliability of this truck which I have owned for 15 years and would like to keep running....
Any ideas are appreciated.
-Fordman
