Max Engine \  retrofitting fuel injection onto a 2.0 liter engine?
Max Engine Max Tech
views 968
replies 2
max headroom   +1y
Has anyone tried to retrofit the fuel injection system from a 2.4 liter engine to a 2.0 liter carburetor engine? Specifically, I have access to a 1995 2.4 cylinder head complete with manifolds and ancillaries and was thinking about installing it on a 1989 D50 (swapping out the 2.0 liter's head and manifolds, etc.). Will that work? How much other stuff do I need: computers? are there wiring harness issues? anything else I should know?
slow50   +1y
youll probably need the entire wireing harness off the donor motor. check out hotrodcoffeeshop.com they know a thing or two about swaping fuel injected 4g63's into d50's.
droppedmitsu   +1y
You will need all sensors, and ecu and engine wiring harness from truck
