Please Help
Please Help
bigrob76
I just bought a 87 mm w/ G63B and when I turn the truck on the temperature guage climbs rather rapidly, within seconds it is peaked.... Do you think that it could be a bhg or something less serious? Any help would be most appreciative..
slow50
is it actually getting that hot? feel the hoses top and bottom thats a good start. i dont think a motor can get that hot in a few seconds from being cold.
bigrob76
No it doesn't feel hot on the upper or lower hose... do you think it could be a sensor?? Or maybe the HG??
droppedmitsu's avatar
droppedmitsu
Definitely think you just need to change out the sensor, I think its almost impossible for it to get up to temp so quick.
bigrob76
Cool thanks, I do however notice maybe just condensation burning off upon startup out of the exhaust ... but I will check the sensor first...
droppedmitsu
as in smoke, if so what color? or what exactly do you mean by condensation burning off upon startup
bigrob76
It looks a little white to me.... what I meant by condensation do you know what water looks like when it boils.... the evaperation of water..
TB
two bills
I agree w/changing the sensor, but I'd also take a look at the oil, for a milky look, and inside the oil cap. A compression check wouldn't be a bad idea.
payrion's avatar
payrion
i know this sounds stupid but is there water in the radiator?...sometimes the hoses will be cooler to the touch if your very low and not moving water....
bigrob76
I checked it it has water in it.... I got all parts on order, head gasket, temperature sensor, head bolts, thermostat, radiator cap, oil, oil filter, coolant.. I think i will just tear into it and see if it fixes the problem... Thanks for all the help, I will keep you guys posted on the progress.
