Max Engine \  87 ECU
87 ECU
Max Engine Max Tech
views 1592
replies 6
dale   +1y
I have a q my ecu burned out yesterday and I have had no luck finding a ecu will the ecu out of a 1987 Max work in my 1990 max
droppedmitsu   +1y
no, 87-89 is carb. And I believe they switched a few sensors or something on the 91-up so I believe you need one from a 90.
dale   +1y
cool thanks it blowed white smoke when it burned out
rxinhed   +1y
Could be the same ECU as the 87 - 89 Montero 4-cyl, too. The 90 will not work.
dale   +1y
i need the 90 is thar noway around the problem or do you know wer i can get one that won't tear a hole in my pocket
rxinhed   +1y
Sorry, misread the intent of your post...the title is misleading.
The 90 ECU is different for the 2.4L and 3.0L. You'll have to locate the correct piece by part number; however, the pars should be the same for 90-92(ish), when Mitsu changed some things around on their platforms.
dale   +1y
So a 1991 and 1992 will work as long as its 2.4L
