88 2.0 oil burning
1 following
88 2.0 oil burning
stevyz
ok i bought this truck and i like it... its 1988 2.0 5 speed
was leaking and burning lots of oil it was leaking from balance shaft seal and front crank seal. also from the headgasket at the rear (all valve stems seals too) still ran pretty good
. so i replaced all the seals on the front of the engine case new felpo head gasket ect .i bought a rebuilt head from a guy i know who had it on the shelf in his shop. it was from rams... he said it only had less than 500 miles on it and the motor it was on threw a rod... and it looked it. nice clean ..was however sooty in some cyls (see photos) so i replaced the head no more leaks and it runs great!!(thats the good news) but it had classic signs of leaky valve seals #1 and # 4 wet plugs was on all 4 before i installed jet valve eliminator kit..all o rings looked like too small to seal well..so i installed the jve kit.. smoking bad in the morning but after 10 mins running down the road cleared up pretty good but after idling 3-5 mins it returned,, compression good cyls looked good when i was in there,,no blowby at all..running strong...so i took off the exhaust manifold and tok some photos of the valve ports ,,,looky there #1 and # 4 exhaust valve seals seem to be leaking.. ..when i was installing the jve kit i inspected all the valve seals with a light ,all looked ok so was hoping it was the jet valve o rings that were causing the problem..put it together still same symptoms ..that is when i took off exhaust manifold and took some pics with my phone..(couldnt get my head in there with the exhaust mani in the way..so the head has all blue replacment type valve stem seals..i got a set of valve stem seals in my head gasket kit..oem i guess 4 are like the ones in my old head and 4 are diffrent type..all the aftermarket ones ive seen all 8 are the same .. this kit has 4with 2 metal rings ,and 4 like i have in my old head(all 8 same) i dont know why these are two diffrent types ..and which side to put the different ones on intake or exhaust...
://farm8.staticflickr.com/7001/6768181927_2534f9f69c_m.jpg#3412
stevyz
i guessed that....... but why do both heads i have ,and all documentation manuals show all same ? is this improved or old design? ,ijust want to make sure im using best design ....any thoughts on what works better or any links to info discussing it? update!!! i found out this is the oem design the updated design is available from fel pro...you have to order it for a 1994 2.4 they list it fitting all the way back to 1982.. ss70598 is the part number of improved all metal clad design.. i ordered them will have them tomorrow... here is a chart shows all mitsubishi engines valve stem sizes ect...i found it helpful
Post was last edited on Jan 30, 2012 04:57. Edited 1 time.
