Max Engine \  wanting to do a v8 swap
Max Engine Max Tech
views 1655
replies 2
1987dodgeram50   +1y
Hi I am new here and I have an 87 RAM 50 5speed and I'm wanting to drop a chevy 350 in it I need some help and information on what I need to get and do to make this work the motor came chfrom a 95 Chevy z71 but I'm goin to carb it I am new at this swap thing never done but I'm bored with the 4 ba nger was raised around v8's lookin for a project for me n my pops to do thanks for all the info in advance
rxinhed   +1y
Any smog laws in your area?
You'll need to change the entire drive train: engine, trans, drive shaft, rear axle.
You may need a body lift to make room for the transmission under the tunnel cover.
All exhaust will need to be fabricated. Connection to the gauges will be fabricated, and a convertor for the speedo in particular. If your truck has a factory tach, that will have be be replaced or otherwise electronically adjusted.
Radiator will be changed for a larger unit.
Yeah, it's all doable. The engine bay is certainly large enough to contain a 350.
hyphybishi   +1y
well only other thing with dropping in a 350 is your firewall will have to b modified a bit to make room for the distributor. and to have alil more room for the fan..
also no need for a body lift. just raise the tunnel its only going to need 3 7/8" higher.
with that kind of motor you want the truck to be lil lower than higher. and of course got to modify ur motor mounts. you can actually use the stock rear end just redo gears and slip yoke. youll notice as you go what you need to do.
