Max Engine \  80+ psi oil pressure?
Max Engine Max Tech
views 1294
replies 0
following 1
synergic   +1y
So I finally got my 1987 Dodge Ram 50 2.0 running with the help of a Weber conversion kit. Now I am poking around to make sure I didn't buy a turd. So far it seems promising with good, even compression, no smoke whatsoever and minimal blow-by but I do have a few concerns:
I noticed the oil light came on which alarmed me. It stayed on no matter the engine conditions. This alarmed me because these oil pressure switches only close at absurdly low psi so I removed it and connected an actual oil pressure gauge. It was pushing over 80 psi. This is a gauge I've used before and trust to be accurate. The motor has 170000 miles on it. I only checked it cold. I will check it warm tomorrow when I get to the shop.
The oil light was on before I changed the oil as well. I couldn't find any specific oil weight for this truck so I checked on ALLDATA and it specified 20w50 for my climate (north Florida). This seems very heavy to me, but I don't know enough about these engines to challenge what ALLDATA says. There does not seem to be a flow issue because I can see the oil splashing around all over in the valve cover.
I have two questions: What oil pressure is your 2.0 pushing? And what oil weight should I be running?
