Max Suspension \  parallel four link or panhard four link fit
Max Suspension Max Tech
views 1295
replies 3
90mm87   +1y
Hey guys will a parallel four link or a panhard four link fit on a mighty max theres a kit im looking at and it comes with a panhard four link ?????
1990 mighty max
2.4l 4cyl
2wd 5spd
payrion   +1y
a parallel 4 link requires the use of a panhard link or a watts link. not sure what a panhard 4 link is, unless its a 4 link with a panhard bar...
pstlwppd25   +1y
I would stay away from watts links and panhard setups. Watts links are good but usually alot of work and expensive. Panhards are just junk. Mines a triangulated 4 link with bag over bars. Its the most common setup for a good ride quality and lift characteristics.
slow50   +1y
i dont think panhards are junk. this guy didnt even say hes bagging it. the major down side to a panhard bar is if you have alot of travel in your rear end it will move side to side but you can set one up right so the side to side movement isnt alot.
