Max Suspension \  lowering mitsu
lowering mitsu
Max Suspension Max Tech
views 1738
replies 6
m0ta   +1y
Need some help lowering this mitsu guys! I wanna do 4in blocks in the rear n was wondering that taper I need to get them? Thanks
droppedmitsu   +1y
Just get a set of universal 4" angled blocks. They don't really have different options on the angle unless you want to change it with shims. But any angled 4" block will work fine.
nate10   +1y
Check to make sure ur drive line dosnt rub when u put the blocks on. I had that problem
slow50   +1y
i had that problem too but only when i hit a bump or something. but i also pulled a leaf with the blocks.
nate10   +1y
U can postiong ur rear diff with the shims towards the ground a few degrees to move the drive line down a little but makes sure u have the right angle on your drive line. Mine dosnt hit an i have 5inch blocks
slow50   +1y
damn 5 inch blocks. i didnt even know they made those. or did you make them?
nate10   +1y
They make 6 inch blocks. Look on a 4x4 site.
