Max Suspension \  steering gear box
steering gear box
Max Suspension Max Tech
views 985
replies 2
following 2
maxxinn   +1y
Hey guys what's up I recently purchased a gear box for my 91 mm 2 wd.Im replacing mine because its worn out and leaks pretty bad my question is.Has any of you done one and if so how difficult was it?Any info would be greatly appreciated thank you.
rxinhed   +1y
Like any other repair, have the right tools on-hand. The procedure is straightforward, remove and replace. Check the PS hoses, replace as needed. Use new fluid, bleed the return line out. Use locktite blue on the steering box mounting bolts, or similar.
maxxinn   +1y
It was pretty simple and straight forward ,steering is alot tighter and gear box no longer leaks.
