Max Suspension \  Lowering 4X4
Lowering 4X4
Max Suspension Max Tech
views 3094
replies 4
dencon509   +1y
Is it possible to lower the 4X4 MM without Divine Intervention - or Eternal Damnation?
'86 D50 4X4
broccolilang   +1y
dude its 4x4...raise it not lower it!
rxinhed   +1y
You can lower by putting blocks above the rear springs, with new U-bolts. The front is simply turning the torsion bars down.
A high school buddy did this one a 4x4 LUV in the 80s. He could scrape his way over speed bumps...
Still, begged the question: "Why?"
dencon509   +1y
Why?
I'm not an off-roader and lifting hurts MPG.
These trucks are not only the best-looking minis, but they look even better lower. The 2WD height would be fine; lower would be better.
We get a fair amount of snow around here and I want to not have to install chains just to go skiing; I'm not a fan of studded tires and winter tires are just another expense I want to avoid.
Post was last edited on Apr 26, 2015 03:04. This post has been edited 1 times.
myd-max   +1y
Don't lower a 4x4... It's bad enough when people lift 2x4s but lowing a 4x4 is just a disgrace and makes four wheel drive pointless
