Max Engine \  timing issue
timing issue
Max Engine Max Tech
views 1069
replies 1
following 2
88todamax   +1y
i got a 88 2.o and i had to recently replace the water pump... well apparently i messed the timing up when replacing it.. but when i went to correct timing by the book it wont crank.. the carb doesnt have a vacuum when turning over the engine yet it blows gas out... but everything is aligned up as per the haynes manual..so im outa ideas and suggestions?
john   +1y
Hi,
I assume the engine now cranks.
Follow the steps in your repair manual and perform a compression test. If your timing belt is installed correctly and your engine is not worn out, your compression should be 149 psi plus or minus 10%.
John
