Blown Head on my 95 mm
ablarge
I am in need of some advice i am in the process of trying to replace the head on my 95 mighty max 2.4l v4 w/fuel injection. i found a head off a 88 m/m but it had a carb. on it is there any way that i can make that head word for me. Or do i have other options in the lines of other interchangeable heads.Thank you in advance for any help you could give me. Aaron
sleeps
No that head is not correct for your block. You may be able to make it work as the blocks are similar but the electronics, sensors, manifolds are not going to work for it. You need a 2.4 head from a 91-95 max. Or a complete motor swap.
Car-parts.com to find complete block from junk yards all around your area.
droppedmitsu's avatar
droppedmitsu
No, the 2.0 had a smaller combustion chamber in the head from what I have read, so you'll probably have the pistons hitting the valves.
Post was last edited on Sep 15, 2011 05:20. Edited 1 time.
sleeps
By george he is right. That specific head is very similar to the 2.4. Right on.
droppedmitsu
Ok cool good to know, thanks for the info. This is firsthand experience btw correct?
N
nate10
i just lost a head on my truck an it was $300 for a complete head at a mits dealer in sacramento an dels machine shop in sac is about 600 for a new head might help
