Max Engine \  Need Help from the gods
Max Engine Max Tech
views 1374
replies 3
following 2
medevack1   +1y
Hey guys i have a 1989 Power Ram D/50 2.6L, here is my problem. Whoever had the truck before me put a new weber carburetor on her to sell her i guess, i have taken it apart and cleaned it, however when i was cleaning the carburetor i noticed the primary opening had carbon build up and the secondary opening was clean like it had never been used. on top of the carb there is a piece that looks like it
rxinhed   +1y
Is the Weber mechanical or vacuum actuated? If vacuum, change the port the secondary diaphragm is hooked up to? Check the diaphragm, too.
Bogging may be caused by a rich condition if the secondary isn't opening.
medevack1   +1y
i believe is mechanical because i dont see a nipple for a vacum line to go into the weber.
medevack1   +1y
ok so i tried everything i know how and still nothing however i turned the ignition all the way towards the front of the engine and she runs a little better.... any thoughts?
