rear axle
rear axle
aaron
does anyone know what kind or what size or anything about the rear in a 86 mm reg. cab 2.0L truck any help would be appreciated thanks
droppedmitsu's avatar
droppedmitsu
Its an 8" Mitsubishi rear end.
aaron
i want to beef it up and want to put a 4.56 or 5.11s in it
droppedmitsu
Well they are pretty stout as is, doubt you will have any problems unless your putting tons of power down. But look around for 4x4 mighty maxs or d50, they will have a 4.2 or something like that rear gear, and just swap it out. There is no 5.xx rear end that I know of.
aaron
Iv got a chevy 350 in it. i belive the yota rear is the same 8in. 28 spline 10 bolt ring gear. and iv found ford made a 8in. 28 spline rear and i can get a mini spool for it to try and see if it well work in the mm rear. and thanks for the help! I'v had a hell of time finding out shit about stuff on this little truck. nobody around here has any idea about this thing. so iv had to do all the fab work from scratch. but i must say its been a pain but should be well worth it the first time down the track! iv got a 350 with about 400hp that came out of a work boat. A th-350 transmission out a 1975 Pontiac. the radiator in the bed like baja trucks. all iv got lift is to put the roll bars from the front of the frame to the end of it, fuel cell in the bed racing seat, 5 point harness and rear and drive shaft. thin off to the track for the first time!
droppedmitsu
Some 4x4 mighty max came with lsd and also late 80s80s montero which had the same axle. That's the only stuff that's going ti work in the Mitsubishi rear end.
aaron
im having a mini spool made for me by a friend. weve made one but it was a rough one. its going to take a little more work
