Max Engine \  accelerator pump
accelerator pump
Max Engine Max Tech
views 1383
replies 3
broccolilang   +1y
I have the stock carb on my 1986 2.0L d50 cant seem to find part numbers on the carb but it says mikuni tried looking up on their site but seems they mostly do motorcycle carbs... just wondering if anyone knew the part number for my carb or better yet a site to order an accelerator pump for it
chriscarpenter   +1y
Good luck finding that part.
You might be better off just replacing the carburetor.
Also a lot of shops won't even touch the Mikui carb because it is difficult to rebuild.
I got a replacement carb from National Carburetor, but they sent me several carbs that did not work. Took me several months to get back on the road because of them.
broccolilang   +1y
it's all good I special ordered the part and switched it out and while I was switching it out I found the one of my check valves was clogged with varnish but got it cleaned up and I'm up and running again (: (: (:
donald   +1y
Hey man, I am in the same boat. What was the part number that you used to place the order and where did you order it from? Thanks.
