Max Engine \  beware transmission mounts on ebay
Max Engine Max Tech
views 932
replies 1
following 1
greenteagod   +1y
Just wanted to give you all a heads up to steer clear of ebay seller ZAMO-ZUAN if you're getting a transmission mount.
He's using the same stock photo as most everyone else on there so it definitely makes me a bit suspicious.
I got mine in and it was horrible. The center safety bolt wasn't even installed. A hole was in the top plate for it to go through but that hole was also half an inch off center. The plate itself was welded only on the back side and the weld itself was insanely sloppy. At one point there was probably a quarter inch gap between the pieces of metal being welded and it was just filled in with weld.
That and the bottom screw holes looked to have had the threads cut with a soft cheese. They were barely there.
Either way, I know getting ebay parts is a double edged sword, I just hate shelling out nearly 3x the amount to the local autozone for what's likely to end up being the same chinese parts.
greenteagod   +1y
Just picked up one from autopartsexpress. Pretty good quality stuff. Heavier duty metal, full welds on both sides of the plate that connects from the transmission to the mount itself, and the actual center bolt thinger is there.
Made in Thailand, which is a hell of a lot better than China for sure.
