Max Engine \  hesitation n cut off with acceleration
Max Engine Max Tech
views 1536
replies 3
following 2
jrb14963   +1y
I got 84 2.0 ltr 4 speed m max. Rebuilt the engine replaced fuel pump n filter along with dist cap otor n wires. Truck starts n idles fine revs up fine but once warmed up if u hit the gas it sputters n pops out the tail pipe n sometimes out the carb. Its dies if u try to gun it . The accelerator pump seems to be wrking when I hit the throttle when engine is off. I don't know whts wrong maybe bad cat coverter or muffles r possibly need carb replaced (32/36 webber swap not an option I'm in cali won't smog:/) any ideas on what's wrong with this truck I need some help
sooloow   +1y
sounds like you got some crossed carb hoses. air fuel ratio isn't right.
sooloow   +1y
i also have a rebuilt carb for 2.0. just needs the choke screw
jrb14963   +1y
Thanks for the replies tuned out to be one of the idle mix screws there was one kinda behind and to the right of the one you can see
