Max Engine \  need help 94 mightymax will not run right
Max Engine Max Tech
views 1158
replies 0
following 1
mightymax94   +1y
I have a 94 mighty max,when engine is cold it will not stay running until engine is warm.
But there is also other problems ,also while trying to get engine warm you have to feather tap the the gas or it will stall ,have to get rims to 3 to 4 thousand. Once engine is warm and you rev engine it cuts out. When trying to drive you have to feather tap gas and barely press gas pedal. Acts like not getting gas fuel filter is good fuel pump,plugs ,wires,distrubter,rotor button air filter ,is good. Tried pulling codes with analog volt meter said it was vehicle speed control sensor,motor position sensor, tps, called auto part store said the first two was dealer parts. Called dealer and nothing they looked up show those parts for that vehicle . To double check I hooked meter back up and now not pulling any codes. Can someone help I'm lost and need to get truck running. 94mightymax 4cyl 2.3 liter automatic. Please help
