Max Engine \  What's the difference between hydraulic & Mechanical Head?
Max Engine Max Tech
views 1274
replies 2
following 2
captaincaves   +1y
Hello, I bought my first D50. It's a '88 4x4 and had a blown head gasket between cylinders. Regardless, I'm replacing the head without the jet valves. What is the difference between the hydraulic and mechanical heads? I think mine has the hydraulic, but I have no idea. It is a 2.6 G54B and has the weber carb. What do you recommend? Thanks in advance, Allen
rxinhed   +1y
The difference refers to the lifters used, either solid or hydraulic. The hydraulic lifter head would use non-adjustable rocker arms. Obviously, the solid lifters will use adjustable rocker arms.
Easy.
captaincaves   +1y
Hello, hey thanks for the respond. I was pretty sure that was it, but not 100%. The ones I have now have the adjustable lifters. Anyway, that clears things up for me. Again, many thanks. Allen
